flow testing injectors
Sand_Man -- you can purchase two injectors from Marren if you'd like. I specifically asked the question. You mention they failed "flow test". Was that actual flow rate, or spray pattern. If flow rate, who tested them, for my future info?
...wish I would have known about RCEngr, would have followed up with them too.
Technical Guru
Having actually dismantled and ultrasonically cleaned my own injectors I would use Cruzin Performance the next time around, they charge $12USD per injector. Other than replacing the filter basket, pintle cap and the o-rings there is not much else that is "rebuildable"?
I think Sandman is talking about mechanical Injectors and some of you are talking electronic. I think with mechanical Injectors, its not only about flow volume, but how they open and spray.
Sandman, best to ask Neil. If they tested them, there's paperwork. I have never seen so much paperwork. I guess you have seen it too.
