Hepl 930 Guru's
Ive got what looks like a outlet on the warm up regulator thats open and need to know what to do with it. I have a outlet plugged off on the intake and was told this is where it should be connected. Here is the pictures. Do I need this to be hooked up? If so I need to find a fitting for the intake.
Mark
Mark
I have found the answer to my question I posted here. The outlet vents to the breather or air and has nothing to do with the fitting on the intake. I had the Magnaflo duel exhaust installed yesterday, now maybe tonight or tomorrow nite when I figure out the 14 pin harness mateing, this car should be done. 84 Carrera harness to 78 930 engine harness.
Glad you found the answer...
I was going to say the fitting went to the air cleaner in the first picture, but then realized I was thinking of the AAV.
I couldn't place where on the intake that was on the second picture. Looks like something has been plugged and epoxied over some.
