911 Turbo (930) Forum 1975-1989
Kudos Mr. Kaspar
Old 02-01-2006 | 03:37 PM
Earlierapex's Avatar
Earlierapex
Default Kudos Mr. Kaspar
Stephen builds a totally badass 930. Just incredible the power he gets. Muchos Gracias.
Starts well, idles well, does great at part throttle, etc. Clutch is a little grabby, but I'll sacrifice something for 550plus horsepower.
Thanks again.
-dc
Old 02-01-2006 | 04:54 PM
jimculp's Avatar
jimculp
Shop Rat
Do you mind breaking down what he did for you, or do you have a link? I'm in Jacksonville- is he in Vero?
btw- did you keep the 4 speed and factory ratios?
Old 02-01-2006 | 05:08 PM
ChristianR's Avatar
ChristianR
550 at the wheels or engine?
Christian
Old 02-01-2006 | 06:08 PM
Earlierapex
485 at the wheels on 1.1 bar. Stephen is in Kansas, so you have to ship... However, it's really worth it to use someone very experienced with 930s (just don't expect your car back TOO soon... )
Old 02-01-2006 | 06:41 PM
PorschePhD's Avatar
PorschePhD
Rennlist Lifetime Member
The car made well over 500 to the wheels with the HF2 I just was not comfortable with the way the car was torqued up. The final runs were about 493 to the wheels.
Old 02-01-2006 | 06:48 PM
Cajun's Avatar
Cajun
Come on Derrick you are KILLING ME!?!?!?!!!!
HOW DOES SHE DRIVE???? I mean I WANT DETAILS!!!!
Old 02-01-2006 | 06:54 PM
Earlierapex
It's phenomenal! The acceleration is absolutely, mind-warpingly unreal. Plant it in second gear at 40, it squats and you are doing 80 in just a couple of seconds. Keep it down in third and 110 is just a couple of seconds more. I'd bet this is a low 11 second quarter car at 130 or more if you drove it like you were mad.
All that and it starts, idles and cruises along at 2500RPM like it's an N/A 911. Very smooth. Just incredible.
I'll shoot some video at some point so you can see it. Just scary fast.
-dc
Old 02-01-2006 | 06:57 PM
Earlierapex
It's an 89, so it has the 5spd. I always liked the 4spd with my old 930s, but the 5spd is quite an improvement.
It would be easier for me to tell you what he didn't do. Basically top to bottom rebuild, headwork, full autronic EFI, 3.2L intake, 3.4L p&Cs, custom cams, twin plug, etc.
-dc
Old 02-01-2006 | 07:03 PM
PorschePhD's Avatar
PorschePhD
Top end?? Has it been long enough you forgot already We did the whole freaking thing. Bottom end, balancing, blueprint, Headers, cams ,intake, valves, springs, flowing, etc
Old 02-01-2006 | 07:24 PM
PorscheDoc's Avatar
PorscheDoc
Exhaust, wastegate, valve covers, pads, rotors, turbo.......
Old 02-01-2006 | 07:27 PM
ChristianR's Avatar
ChristianR
Do you think running the car at 1.1 bar will shorten the engine life? My car has a switch for .8 bar and 1 bar, it makes 545ft/lbs at the wheels. I always ask my mechanic about setting it at 1.1 bar and he says absolutely not.
What's your thought PorschePHD
Christian
jimculp's Avatar
jimculp
Shop Rat
Thanks for the info all- which IC did you go with?
Old 02-01-2006 | 08:07 PM
PorschePhD's Avatar
PorschePhD
I think if you build an engine with that in mind that there is no reason why you can not run that amount of boost. CIS cars..NO WAY. But EFI opens up a whole new range of possibilities. When constructed right the motor will live there. The caveat is if the engine is not mapped in this area then you need to be cautious about turning up the boost.
The motor runs very conservative AFRs and timing compared to most, especially up top where heat really becomes an issue. We have taken all the precautions to run in this range and a tad more for street only.
Derick also runs a track file which is 10lbs of boost.
Jimculp, he is running a custom modified intercooler made in house.
Old 02-01-2006 | 08:45 PM
DeanM's Avatar
DeanM
Hi Stephen,
What is the CR?
Nice build as usual.
Dean
Old 02-01-2006 | 08:58 PM
Chet 930's Avatar
Chet 930
Hey....I can see a little bit of butt of my 930 in the 2nd pic
Quick Reply: Kudos Mr. Kaspar
