Help! 930TT firesale new rig ready..EFI, every mod possible
There's well over 150k in my current car..'87 US spec 930 as base.. looking to buy another Protomotive rig that is being built. Will move for 50ish... THIS car is a steal at that price.. I'm not one of the ''rich guys' I need to move this for a gt2 2wd 993.. Some help please..:-)
Todd Knighton (Protomotive) originally built the motor and Prototech did a *major* rebuild approx 2400 miles ago.. here's the goodie list; last(only) timed run was 0-85 in under 5 seconds..Protomotove won the 996TT shootout and has/had the fastest street legal Porsche in US.. This car was built for comfortable street use and longevity.. NEVER tracked. This car should not require anything for quite a while…and has NEVER been abused..
This car is beautiful and sexy, sits perfectly, sounds AMAZING, handles great, is comfortable and is stupidly fast…it also seeps/leaks NO oil.. I have built/owned 20+ VERY high performance cars and this is the pinnacle.. if I wasn’t mid 40’s and wanted a car with a little more margin for error due to my reflexes being a little slower I would never sell her…
You could not replicate her, even with less expensive pieces for under $110k…
Approx 2400 mile currently (engine/clutch) with other (non-engine) work performed since 2001 approximately. (15,000 miles) 900 miles currently on odometer effective 9/15/05. Approximate mileage on chassis 73,000
(2) New Garrett Super-60 turbochargers
Stainless 1 5/8” equal length headers
Stainless exhaust/stainless dual outlet muffler
Protomotive, 2.5” core, polished intercooler “high-rise” model; works in conjunction with custom tail/decklid for increased airflow over standard Proto IC/tail combination
Stainless racing blow-off valve
Bosch Motronic EFI system with Protomotive chips
Absolute pressure sensing/speed density/throttle position and related soft-hardware mods
There is NO MAF in intake stream!
Big bore throttle body
(2) MSD 6A Ignition modules
(2) MSD Blaster 3 coils
(2) HKS racing waste-gates
In-dash HKS electronic boost controller
Porsche twin-plug distributor w/ vent kit
Custom wire set(s)
Dual K&N air filters/inlet fabrication
Silicone hoses where possible
Porsche high volume oil pump
New Mahle Sport fully-finned 3.3 pistons/cylinders w/ 7.5-1 C/R
Ported, flowed, twin plugged cylinder heads;
3-angle competition valve job
150/300 lb. comp valve springs w/ windaged titanium retainers
Protomotive fuel regulator
Nirerist (flame ringed-interlocking) heads/cylinders
Webcam 20/21 high lift camshafts
New Porsche GT2 head studs
Carrera ported/flowed and extruded intake manifold
52 lb. fuel injectors
Stress relieved and micro-polished crankshaft
Stress relieved connecting rods
Raceware rod bolts
.2mm oil squirter modifications
Ductile molybdenum insert rings
.5 mm base shims
New rocker followers
New chain tensioners
Viton gaskets and seals; Glyco/factory rod, crank and intermediate shaft bearings
Custom heat shielding/wrap for critical components
New Porsche 935 pressure plate and 935 clutch disc
Custom LARGE full-width under-pan condenser..works very well with fresh charge!!
Custom stainless heater box and ducting.. works well!
Freshened Porsche G50/50 transaxle conversion
Swepco gear oil
Full hydraulic clutch actuation conversion; master/slave/lines/pedal etc.
Weltmeister hollow adjustable front and rear sway bars
Gun drilled hollow front torsion bars
Adjustable spring plates
Front multi-point strut brace(camber truss)
Front Bilstein Sport struts; rear Bilstein Sport adj. coilovers
Car suspension was fully setup, lowered-rack mod, corner balanced, aligned etc….
SCCA approved 4 pt. Roll-bar painted to match car
Dual Halon fire extinguishers
Racing 4 pt. harnesses with 5 pt quick-release;seatbelts still attached
Recaro leather/power/inflatable lumbar drivers – matching pass seat w/ Recaro frames
Porsche/Brembo Big Red Calipers F&R; Silver painted
Cross drilled and ventilated Big Red rotors with stainless/billet mounting hardware
system flushed/filled with ATE Super Blue fluid
SS brake lines and working parking brake
Bumper air ducts for front cooler/brakes
Speedline forged 3-Pc wheels 18x9, 18x11 rear; Alessio model; Porsche wheel emblems
Pirelli Pzero asym 235/40 fronts 295/35 rears
C2/Turbo bumpers, rocker panels, front/rear and center-rear lenses/turn-signals
Factory 1987 paint (orig color)
Electric Sport mirror conversion
2 Bar VDO in-dash boost gauge
220 MPH speedometer
10k tachometer –
Full silver gauge faces-bezels; including Boost
Billet pedal set
Momo “Race” steering wheel
Carbon fiber shifter
Remote “radio-FM” Pager Alarm System w/integrated locking
New Porsche “turbo” Stainless door-sills
New Porsche carpet edge-sill guards
New Porsche Sunroof gears, tracks and weather stripping
New door weather stripping
Prototech rear lid/wing for intercooler
Bosch H5 headlights
Sylvania Silver Star White bulbs
Kenwood flip-face stereo, (4) component speakers in doors, 3-way’s in rear deck w/ subwoofer
MTX five channel amplifier
SS 4” muffler tips
Professionally tinted windows
New Battery
More high res pics here..
http://members.rennlist.com/edpurplett/
ejpjr98@yahoo.com
or call Ed @ 610.574.0988
Custom wire set(s)
Raceware rod bolts
.5 mm base shims
Swepco gear oil
220 MPH speedometer
10k tachometer –
Billet pedal set
Bosch H5 headlights
SS 4” muffler tips
New Battery
ejpjr98@yahoo.com
