For Guys Running Blow Off Valves
Guys - If you are running BOVs, would you be able to please post a pic of your set-up? This is my next installation, as I would like to reduce the compressor surge at 1bar.
Thanks!
Yasin
Thanks!
Yasin
FWIW we've found our Stock Toyota BOV to be better than any on the market. Go here for a good write up: http://www.jekylhyderacing.com/bov.htm
The By-Pass-Mode alone is worth it. It'll improve your low end power and throttle response when off boost. It allows air to go around the turbo when under vacuum. Don't forget the engine has to work to pull air over the impeller when not at boost. That robs power.
Go here for a good photo of the unit on the MR2: http://mr2.noegruts.com/engine/engine.htm
And here is a basic operating description from the Toyota Mechanics Manual (what we refer to as the Big Green Book- BGB)
Very interesting Senna21. I would assume that drawing the air on vacuum spins the turbo at some speed, with the toyota bypass would the turbo be spinning much slower and what effect if any does this have on spool up? Would it be insignificant? What is the vacuum source for the two lines and in which line does the VTV go?
Stephen, Kevin....thoughts?
Also, and I’m not sure on this, we have the BOV routing air directly around the Turbo before the intercooler. The intercooler is another place where air has to be dragged through under vacuum. It may be better to mount the valve after the intercooler as well allowing the most direct path to the intake.
Thoughts?
