Bolt-on Garrett GT35R turbo for 911
#78
Tim, Kevin,
Do you think a turbo oil cirulation kit that runs after you shut off the engine will be almost as good as the water cooling ? It would be much simpler to setup - and many kits already exist.
Thanks,
Norm
Thanks,
Norm
#79
The design of the Garrett Ball-bearing, bearing housing has the upper water-cooled passage. Having 180-210 degrees of water in that housing, stabilizes the entire unit.. This includes oil that is passing through.. Right now you need to decide what is easy for you, and what you can physically do.. If you have some time grab an infrared heat gun and look at your temps when you get into the pits.. This should sway your decision as to which way you want to go..
#81
[QUOTE=TurboTim]
Tim, are the replacement carts available yet from Garrett?
Originally Posted by Kevin
Yes, most High Flows are shipped without the Zero Clearance process. I know the 35's very well.. along with all of the BB units.. The real question is that one cannot rebuild the BB units.. Once it fails one has to fork out the turbo price again. Garrett is not offering replacement cartridges..
From what I am understanding there will be replacement cartridges very soon for those that might need them down the road.
#82
Norm, water-cooling will definately add life to your turbo's.. However, the extent is not known.. Try it and see.. There are KKK alternatives.. I know about your ECU issue, but that can be solved also.. Personally I'd dump the Zytec and switch to a Autronics and tune to your hearts content.. The turbo that you should be running is my billet aluminum Stage 4...
what's your "billet aluminum stage 4" all about?
#83
By the way, I did simply add the oil cooling through the water jacket and that solved the problem. It did stabilize and lower the temps. I used to have to replace turbos every 4 hours. I now have 5 race weekends on them and they are still like new.
So thanks for the suggestions...
Norm
Norm
#84
The HF is reference to my large high efficient compressor wheel that can be installed/CNC'd into 7200, 7006, K28's and K29's.. Zero Clearance is my process of running the compressor wheel to a "0" clearance between the blade tips and housing.. The benifit is that that the compressor side efficiency jumps to the mid 90%.. Boost is available sooner, and faster... Engine torque builds earlier as a result..
your HF higher efficiency compressor wheel is available with or without it running "0" clearance correct ? What are the pro's/cons of an HFS with and without running ZC?
Are the HFS compressor wheels also easily installable/CNC'd into an existing 7006/7200? If so, what does it take to upgrade a 7006/7200 to your HFS in terms of $ and time?
#85
Norm
Norm
#86
I'm not sure which spec Garrett BB turbo 9m fitted to mine but I know it's oil cooled, it says Garrett on one side, I think the rest of it is a 9m creation, what a turbo though, just incredible!
#87
diabolos88, the Stage 4 billets are based on K16 and/or K24's (different turbo).. Yes, the Z/C process can be applied to the K27 series.. Yes I can turn any 7006 or 7200 into a HF, Z/C is an option.
#90
Hello Guys,
Norm , what kind of oil temps are you seeing ? How are you returning the oil from the turbos and at what rate if by Electric pump ?
While Garrett has stated that all their Ball bearings GT turbos has to have coolant lines attached for the turbo to last , i have seen applications where this has not been a problem if the oil temps are good and the return is done right ...
