1976 930 Turbo
![Wink](https://rennlist.com/forums/images/icons/icon12.gif)
Hi I am trying to find out more info on my 76 930, it is all original, excellent condition with only 46,000 miles, factory orange with hood pins, a.c., It has a metal plate on glove box that says Mecki, the man I got it from 2 years ago bought in 79. Thanks for any info, Malinda
911 Turbo - 1975 to 1977
Engine Turbo 3.0
Cylinders Six
Bore 95 mm (3.74 in)
Stroke 70.4 mm (2.77 in)
Capacity 2993 cc (182.64 cu. in)
Compresion ratio 6.5:1
Maximum power (DIN) 260 @ 5500 rpm
Maximum torque (DIN) 254 ib.ft @ 4000 rpm
Output per litre (DIN) 87 bhp
Intercooler No
Fuel octane rating 96
Engine design
Layout Air-cooled, six-cylinder, four-stoke, horizontally opposed.
Dry sump lubrication
Crankcase Light alloy
Cylinders Light alloy
Valve position One inlet, one exhaust; inverted V-pattern
Valve operation Single overhead camshaft for each bank, chain driven
Fuel supply Twin electric pumps
Crankshaft Forged steel, in eight main bearings
Fuel injection Bosch K-jetronic continious injection system (CIS), with KKK turbocharger
Electrical system Capacitor discharge, contactless
Transmission
Clutch Single dry plate, 240mm diameter (9.6 in)
Manual gearbox Four forward speeds, with Porsche synchromesh
Final drive Spiral bevel differential, with limited slip option
Ratio 9:38 (4.222:1)
Chassis, suspension
Front suspension Independant, with wishbones and MacPherson struts Torsion bars, telescopic shock absorbers, with independent semi-trailing arms layout
Anti-roll bars Front and rear
Brakes Front, 284mm Ventilated
Rear, 290mm Ventilated
Servo No
Wheels Light alloy, forged 7J x 15 front until 1976
8J x 15 rear until 1976
Steering Rack and pinion
Fuel tank capacity 80 litres (17.6 imp. gal)
Dimensions
Wheelbase 2272mm (89.45 in)
Track, front 1438mm (56.61 in)
Track, rear 1511mm (59.49 in)
Length 4291mm (168.94 in)
Width 1775mm (69.88 in)
Height 1310mm (51.57 in)
Weight 1195KG (2635 lb)
* Weights according to optional equipment
Types Performance
This model was supplied as a coupe only. 0-60 6.1 secs
0-100 14.5 secs
The number registered in the U.K. is 36. Top speed 153 mph 246 kph 5,900 rpm
Engine Turbo 3.0
Cylinders Six
Intercooler No
Engine design
Transmission
Chassis, suspension
Servo No
Dimensions
Types Performance
0-100 14.5 secs
