Mixture Question
Mixture Question
Gentlemen,
What voltage value should I be looking for when checking my mixture with an O2 sensor? My 85 930 has the Euro (non lambda controlled) system but the pipe before the turbo has a sensor bung. I'm currently getting about .71-.74 volts, engine warm at idle.
Thanks in advance!
Thanks in advance!
.5v is 14.7:1 or 0% CO, .71-.74 is probably around 1% CO or 14.2:1. You can actually lean out to 0% CO if you want but you better make sure you have enough fuel up top. The equivelent voltage to CO% will probably put you at .75-.85v by the book. You might invest in a CO tester to know this.
Thanks Brent. A CO meter is next on my tool list. A few list searches I did indicated that some of you guys are running 4%-5% CO... it was unclear if this was at idle or WOT though.
If you want to really do it right then bypass the CO meter and install a wide band O2 system. I recommend it even more for CIS cars since things change alot because of heat, cold, humidity, dense air and altitude. 4-5% is alot but some people need it in order to keep safe up top. The goal would be to run a lower CO% if possible. This is at idle, 195 deg. oil temp and 950 +/- 50 rpms. I can run 0-.5% CO at idle with my setup safely.
This question is for Brent I wondering wahat did you mean by a wide ban O2 unit. Second I want to know if I set up the O2 for the .75 volts would the system be at the right mixture up top?
Obviously a wode band O2 tester on board would be ideal to see what you have in real time conditions.
I really need to verify mine. I know it's running rich, as it sucks gas down, but with no tests of any kind here in SC, not a single place I've called has the equipment to check it.
Jim
Eddie,
A wide band O2 is a better mearsuring device than a narrow band O2 for monitoring A/F.
The second part of your question is a good one. Once you mod you car for more power than stock is when you will need to run a fatter CO. BUT, the big mystery unless you get the thing on a dyno to monitor the A/F is how much more CO you will need and if it will be good enough with or without enrichment.
Jim,
Yes, I had the Gunnson gastester digital until I got my wideband. It will be good enough to start with but you won't know what your A/F is up top unless you get a wide band on board or go to the dyno. Depending on your setup you might not have a choice but to run a very rich idle to get the fuel you need up top. I spent some money and time to run a lean idle and cruise yet have plenty of fuel up top with a good fuel curve unlike the CIS curve.
Jim,
Brent,
Is a narrow band O2 sensor worth installing? I used a Cyberdyne unit from Jeg's ($39.99 or so) on my turbo Volvo for peace of mind. I just made sure I was staying slightly rich at full boost (16psi).
I plan on doing a dyno run in the near future.
Thanks,
Steve
Thanks,
Steve
No, remember with a narrow band you are using a 14.00 02 sensor. You get a 14.00 dollar reading. They are most accurate around 14.7 and can not move near fast enough on a turbo car to give real time info.
Originally posted by Rocket
What about the Gunnston (sp?) CO tester. Didn't you have one awhile back Brent?
