911 Turbo (930) Forum 1975-1989
splitting block halves
Old 02-29-2004 | 01:49 PM
irover's Avatar
irover
Arrow splitting block halves
Hi. I bought a 930 1978 with the motor all in pieces. Now trying to open the block halves to inspect/change the bearings. Is there anything behind the flywheel that holds them togeather? I would like to leave the wheel on for now, but it seem to stick in that end, and maybe i have to take the wheel off to separate the block?
Any ideas,
Peter
Old 02-29-2004 | 01:59 PM
PorschePhD's Avatar
PorschePhD
Rennlist Lifetime Member
Yes, there are two studs on either side of the journal. You need to pull the flywheel to get to them.
Old 02-29-2004 | 05:22 PM
irover's Avatar
irover
thanks, that's what i thought!
Old 02-29-2004 | 10:03 PM
Kevin's Avatar
Kevin
Make sure that you get the nut from one of the main through bolts inside of the front chain housing area (drivers side)
Old 03-01-2004 | 06:58 AM
irover's Avatar
irover
Yep. found that one. Do you also know what size the XZN screws are at the flywheel?
Quick Reply: splitting block halves
