Rear Reflector
Rear Reflector
My rear reflector looks as if the clear coat is coming off of it. Does anyone know how to remove the rest of it, or should I buy a new one?
Chris
82 911SC
ccoleymd@yahoo.com
Chris
82 911SC
ccoleymd@yahoo.com
There is a plastic refinishing kit called "micro-mesh" or something close to that used to refinish plastics on everything from airplanes to boats. You basically sand the plastic smooth with different grits of sand paper. Starts with coarse grit sandpaper and works up to about 11 or 12000. Even works on clear lenses.
Probably around $50.00 Chuck
