Front Hub Grease Seals
#61
The higher the speed of the bearing, the less grease it can hold, up to a point. I forget now how much Porsche says to put in the bearing, but the point is you don't pack it all the way full. Don't overtighten the spindle nut. Just until you can't move the washer by prying against it, then back off around 10 degrees. Check the wheel for slight play.
I still remember being on the phone with Steve Weiner when I discovered my 911 hubs were loose. I lost the rotor and pads along with the bearings and races. That's what I get for doing my own PPI.
#62
I haddah Google dat
My high school autoshop teacher pounded this into us. I still don't buy that there needs to be play, but I do go until the washer can only move by a bit of pressure with a screwdriver. I'll spin a hub around 40 revolutions or more before I put in the cotter key just to be satisfied that I've got it right.
#63
I remember when I was about 16 pulling a trailer home from Glamis with my three wheeler in it. Wheel bearing chunked on freeway in the middle of the night. We pulled the plate off of it and put the ATC 110 on the tailgate of the truck and drove home. Stupid trailer is likely still sitting there.
#64
I haddah Google dat
There's a guy who is famous within the retail fuel industry, from Palm Desert, who I hope to go meet someday. I might continue south in search of your trailer.
#65
That story puts a smile on my face. Just the thought of you on a 110 ATC would have been a spectacle. Did you push it up and down the sand dunes?
#66
I haddah Google dat
^ Haha! At least you guys had a camp.
Around here, we used to go to Pismo/ Grover Beach. My Gramps used to call it "**** 'Mo". Anyway, I bought what was called the Baja 1000 Kit for the Honda ATC 250. Sander's Honda in Visalia sold it, and Eddie Sanders raced it back in '82. It punched the cylinder out to 350cc, raised the compression, and had honed out ports till they were paper thin. That thing shakes the ground when it's idling, and you can't steer until you're in 3rd gear.
I raced my buddy up Competition Hill in Pismo. I clear the crest of the hill with throttle pegged, and see a helmet. Helmet goes down, down, down as I get air. My buddies' parents were there with a VCR camera filming us, literally. We got home and played that tape over and over. I cleared the guy, sitting on a 200 SX. He watched me fly over him and almost wipe out trying to land. I saved the landing and had to stop to catch my breath.
#67
This is my daughter that is now in Mexico City learning Spanish. My brother and I built an ATC 70 into a monster 88cc bike with EVERYTHING available at the time. Carb, pipe, head, cam, cylinder, piston, etc. New sprockets, rims, tires, chain, etc......MONSTER that is even plenty strong enough for me to ride. The only thing I'd change now is the next set of tires will be flat tracks.
Same kid that is hanging off my Hobie Cat:
#68
So, it should have slight play huh? I wasn't aware of this. I did read about not overnighting the clamping nut, but how much play are we talking? Meaning, how much should force with a flathead should I be applying to the washer, and how much play am I looking for in the washer?
#69
Zero movement or rattling of the wheel....slight movement of the washer when pried on with a screwdriver. You don't want to crank it too tight because too tight creates friction. There isn't an easier hub to work with. Just check your work after everything is broken in and driven a while.
#70
Spec says you should be able to push the washer side to side with a screwdriver without using leverage. I always use a little bit of leverage myself, though, because if I don't it feels like there's simply too much play in the wheel when I'm done.
Also worth noting that the inside bushings of Bilstein struts can wear out over time and mimic the feeling of too much play in a wheel bearing. So keep that in mind if you have Bilsteins.
#71
Edit: Also, anyone have a torque spec on that Clamping Nut for the Spindle???
-Cam
#72
Team Owner
your likely not going to get a torque wrench in there anyway if its what im thinking, isn't it just a hex bolt ? Just reef it up with an allen key and move on
#75
I haddah Google dat
