911 Forum 1964-1989
Odometer problems.
Old Nov 14, 2003 | 02:15 PM
jonjeffryes's Avatar
jonjeffryes
Default Odometer problems.
Hi all,
1000 miles into my ownership and the odometer & trip start playing up. Both will run for up to a maximum (so far) of 60 miles and then stop recording.
If I reset the trip to 0, sometimes it will start working again. Other times, it only starts working after stopping the car, powering down and restarting.
Could it be the sender? If so, where is it on the 911?
BTW, the speedo works all the time.
Regards
Jon
79 SC Targa Sport
79 928 auto
Old Nov 14, 2003 | 02:25 PM
84porsche's Avatar
84porsche
It sounds like the odometer gear might be failing. I pushed the trip to zero and my odometer and trip stopped running altogether and have not moved since. I still have to send it to a repair shop.
Old Nov 15, 2003 | 11:44 AM
dial911's Avatar
dial911
Odometer and tripmeter failure is usually caused by one thing.....pushing the trip reset **** *while the car is moving*. Don't do it, ever!
Send your unit to N. Hollywood Speedometer for repair.
Old Nov 15, 2003 | 12:12 PM
scottb's Avatar
scottb
Some people have fixed the gears themselves. I think the parts are available at www.odometergears.com.
Old Nov 15, 2003 | 01:08 PM
ron mcatee's Avatar
ron mcatee
The sender is on the side of the transmission.
Old Nov 18, 2003 | 10:31 AM
Ken From KLA Industries's Avatar
Guys,
I make the gears for both Euro and us cars. All I need to know is the year. They are on WWW.KLAINDUSTRIES.net I make mine out of glass impregnated nylon and also out of polucarbonite.
Ken
Old Nov 18, 2003 | 03:41 PM
jonjeffryes
Ken,
My problem is a random one, i.e. It usually works for the start of the journey but stops after anywhere between 30 - 50 miles. Carry on driving and it might start again.
I did a 300 mile round trip today, the odometer read for the first 32 miles then stopped. At about 100 miles, it started to read again until 74 miles and stopped againand that was it.
I reset the trip with the car shut down at 150 miles. On the return journey, the odometer/trip didn't read until the last 10 miles.
Would this be gears...a had a similar problem with my 928 which turned out to be a bad connector to the sender on the gearbox.
atvb
Jon
Old Nov 18, 2003 | 08:17 PM
3.2SLANTNOSE's Avatar
3.2SLANTNOSE
Hi Jon, sometimes the odometer gear, if it is a metal one, instead of breaking, it can come loose on the shat. Generally, this happens to the metal type gears, the plastic ones usually just get ground up. You can go inside to determine what is what. Just takes time to do, thave to pry off the bezel, if it is the metal type gear, you can either epoxy it in place on the shaft, or try to peen (stake) it back in place. BTW, did you get your window switch working?
Old Nov 19, 2003 | 04:40 PM
jonjeffryes
Hi,
I'll pull the speedo this weekend....I also have a set of yellow overlays for the instrument faces....dare I?
Have not yet fixed the window switch, the 928 is at a photoshoot for one of the UK classic car mags tomorrow so i've had to turn my attention there this week.
The 911 will be featured in a future issue. Fame at last!
Regards
Jon
Old Nov 19, 2003 | 08:17 PM
Harry Talmon's Avatar
Harry Talmon
3rd Gear
I also have problems with my 72 odometer. What is the turn around time at N Hollywood Speedometer? What do they usually charge for the repair?
Old Dec 3, 2003 | 12:37 AM
Damomma's Avatar
Damomma
8th Gear
I just spoke to them about an R&R on my 78 speedo, -- $130. My odometer is working the speedo is off until I hit 100.
Old Dec 3, 2003 | 08:46 PM
Russ L.'s Avatar
Russ L.
hI everyone,
I had a similar problem with my 84 cab... after taking the speedo apart, i fuond the primary gear [light plastic] just fell apart to the touch. Well after that I fuona a man by the name of Jacob from Speedometer Plus in L.A. Calif. He described how to take off the speedo needle...but I "GORILLA'D IT" and made it into a kit... I then sent him the whole thing and he repaired it for about 180.00 U.S. ...The turn-around time was a week and it's been in and working great ever since...
About changing the faces on the meters...be VERY careful when removing the needles. Some come off easier than others!
If your speedo works when it feels like it ,I would look into the electrical end of the system before I ripped the speedo itself apart. A bad ground or loosely secured connector would give the on again off again symptoms that some of you are talking about.
Hope this helps.
Russ
P. S. Jacob@ Speedometer Plus
8916 Ellis Ave.
L.A. california 90034
1-877-900-9009
Old Dec 4, 2003 | 01:38 AM
hoffman912's Avatar
hoffman912
The Hoffinator
if you dont do it yourself, i second the recomendation to have it fixed by North Hollywood Speedometer. they do excellent work.
