Turn rotors on 911 ?
Team Owner
Originally Posted by rusnak
I would also replace bearings, seals, and pads. Maybe the caliper seals, depending on how they look.
That's only 40k miles of pleasure driving. Inspect and Repack should do it.
If you buy new rotors make sure you prepare them properly. Then you have to heat cycle them.
Richard Newton
Brake Rotor Prep.
Richard Newton
Brake Rotor Prep.
If they are OEM rotors with a lot of life left it could be worth turning them but those grooves look pretty deep and I think a lot of material will have to be removed for them to be smooth again.
