power brakes?
You'll need a new, different master cylinder, the vacuum cannister, a source for the vacuum, the pivot or bearing assembly (big chunk of aluminum at the end of the master cylinder), rod from brake lever up to bearing assembly, likely something different in the pedal cluster for the brake pedal to use the connecting rod, and some etc.
