Weber carbruator adjustment????
When checking/setting the proper fuel discharge from the dump tube what is the length of time that you hold down the linkage? The reason that I ask is because the amount of fuel changes considerably depending on length of time that the throttle is held open. Any information would be appreciated.
Thanks,
Erick
Thanks,
Erick
RL Technical Advisor
Hi Erick:
Assuming that you are referring to the accelerator pump outputs, and setting injection quantities,...
this is what I do.
Holding that vial under the nozzles, I simply operate the throttles as I would with my foot; push them open kinda quickly and release.
Adjust the little threaded rod to get the proper injection volume, and you're done. I set them slightly rich if you are using larger-than-normal main venturies to prevent a flat spot.
Hope this helps,
Hope this helps,
