Intake runner & airbox install
Received my new version airbox and need some input as best installation - do I pull all intake runners and install to airbox then bolt intakes in or do I tighten rubber tubes from below and leave runners on?
Team Owner
Take all runners off and build it up on the bench , then drop it in and tighten. id leave the front runners slightly loose as you can access the front clamps for the rubber couplings if I remember , so you can make some small adjustments .
