911 Forum 1964-1989
Home Built Hot Rod (With full build videos)
Old 09-18-2020, 07:25 AM
  #316
MFX233
MFX233's Avatar
After the high of finally, after 5 years, of getting Harry on the road, he rewarded me by breaking down the very first day...
Old 09-18-2020, 08:09 AM
  #317
Kobalt
Kobalt's Avatar
https://youtu.be/ocRFnTR_xfI
Bummer!
Thanks again for all that work you put into theses videos!
MFX233 (09-18-2020)
Old 09-18-2020, 11:52 AM
  #318
Cloggie
Lost *******phile
Cloggie's Avatar
Oops, my bad....did not watch the video all the way....this blasted work thing got in the way Your speedo problem is quite a bit different, I assumed it was shifter rod....which is what I wrote below...sigh....
"It is possible to replace that seal with the transmission still in the car...I have done it. I used a drywall screw (very sharp point) to hook into the seal through the cover plate in between the front seats, pulled it out and then it was easy to tap in a new one. Needless to say this is with oil out of the transmission and the shifter linkage disconnected.
If I recall, and this was 15 years ago, I actually put in two seals and had no trouble since the repair, so that might be an option for you if you are worried about scoring on your shifter rod"
Really enjoy your series on YouTube, but I remain worried about your hydraulic clutch mount on the transmission...we shall see.
Cloggie
Old 09-18-2020, 05:40 PM
  #319
MFX233
MFX233's Avatar
If I recall, and this was 15 years ago, I actually put in two seals and had no trouble since the repair, so that might be an option for you if you are worried about scoring on your shifter rod.
Cloggie
I think you must have skipped half of the video . Seal is not the problem
Old 09-23-2020, 06:36 AM
  #320
MFX233
MFX233's Avatar
tried buffing Harry previously and did a pretty terrible job, so I decided it was better to get my mate David over to give me a hand and some pointers on how to get it looking the way it should.
Old 10-14-2020, 06:08 AM
  #321
MFX233
MFX233's Avatar
In this episode. I pull out the engine to sort out the gear box leak issue.
Old 10-15-2020, 11:27 PM
  #322
Anglocanadian
Anglocanadian's Avatar
Lightbulb
Look on the bright side , after dropping the engine a few times you get really good at it and then you can see if you can do it faster each time !
MFX233 (10-16-2020)
Old 10-20-2020, 07:35 AM
  #323
MFX233
MFX233's Avatar
This week is not the greatest for Harry 911, damaging the paint again. Grrrrrr... Then I replace Harry's shocks only to have some other unexpected issues.
Just one more (10-20-2020)
Old 10-28-2020, 06:40 AM
  #324
MFX233
MFX233's Avatar
In this episode I reindex the torsion bars on Harry, which is how you can raise or lower your Porsche 911, and then I finally get around to taking you guys out on the road and and letting you know how it drives.
Old 10-28-2020, 11:31 PM
  #325
Anglocanadian
It sounds awesome Jeff !
MFX233 (10-29-2020)
Old 11-19-2020, 04:03 AM
  #326
MFX233
MFX233's Avatar
This week it is time to do something about the tired old exhaust on Harry 911 and bring it up to match the rest of the car.
Old 11-25-2020, 03:59 PM
  #327
MFX233
MFX233's Avatar
In this episode, I finish off the bi-modal exhaust that I built last week and then Mrs Jeff finally gets to drive Harry 911.
Old 11-25-2020, 04:45 PM
  #328
myles engler
myles engler's Avatar
Great video! Thank you for all the entertainment and information! One question, what is up with the tach moving bouncily through the rev range? Noticed in the video it does that while the engine is in gear and under load.
Old 11-25-2020, 05:26 PM
  #329
MFX233
MFX233's Avatar
I think the tacho needs more dampening (better shocks ) as when it moves quickly it takes a while to settle down.
Old 11-29-2020, 01:43 PM
  #330
Neil Harvey
Neil Harvey's Avatar
Jeff,
You are very welcome and thankyou for the kudos's.
Once you have the engine fully mapped, I'm interested in knowing how the Torque curve looks with that new cam. This was one of the new designs we did for these air-cooled engines.
nh
Quick Reply: Home Built Hot Rod (With full build videos)
