911 Forum 1964-1989
H4 headlamp upgrade question
Old Sep 26, 2003 | 08:37 AM
traveler's Avatar
traveler
2nd Gear
Default H4 headlamp upgrade question
I just received the Bosch H4 headlight upgrade including the high power headlamp relays (one for each side). All the parts are here and I have read the technical article on installing the headlamps but there are no instructions anywhere that I can find on installing the relays.
Also, what's the process for aiming the headlights without a headlight aiming tool?
Old Sep 26, 2003 | 09:36 AM
jim912928's Avatar
jim912928
Not sure of the relays, but the "garage mechanic" way of aiming the headlights is pull it out in the driveway, close the garage door, turn on the lights, and direct the beams with the two adjustement screws watching the pattern as they hit the garage door. This way is easy to make sure they are aiming straight and parallel.
Old Sep 26, 2003 | 03:36 PM
steve911's Avatar
steve911
Do a search on pelican for 'msucro' - you should find a bunch of threads on the wiring for the relays. If all else fails, you might email marcus sucro - his relay kit comes with an excellent set of instructions on wiring the relays.
