87-88 carrera and cup wheels
Hello,
I'm just wondering if the newer 17" or even 16" cup wheels can be fitted on the 3.2 Carreras? Is it direct fit or has to be modified? If there's pictures, please post. thanks
Here is a photo of my '87 Targa, which originally came with BBS wheels, and which I changed to Cups. Required wheel spacers front and rear, but worth it to me for the change in appearance.
Tom
Tom
Yup, 17's. Re.: Targa Top: Just a little water ingress when I wash it, but I haven't had it out in the rain yet. My mechanic knows that it is my daily driver, so he said "Just carry a towel in the rainy season." We'll see what happens this winter...
Tom
Tom
hello,
I am looking for the offset of the OEM fuchs alloys. i have a 86 with 16x6 and 16x7. any idea what the offset of these whells are? i am trying to install 16x7 and 16x9 with offset 55 front and 70 rear. for the 2 of you that have the cup wheels, what size spacers are you using front and rear.
thanks
thanks
hello,
those of you that have late style wheels on your carreras, do you have any idea what the offset is on the stock fuchs alloys? and what size spacers did you need to use to make the newer wheels fit? i have bought some 16x7 and 16x9 with offset 55f and 70 r and nobody seemd to know what size spacers i need.
thanks
brandon
86 carrera
thanks
brandon
86 carrera
Originally posted by BPBevins
hello,
thanks
brandon
86 carrera
hello,
thanks
brandon
86 carrera
My Cups are 17x7 55 Front and 17x9 55 Rear. My wrench not only wanted to provide clearance on the inside of the tire, but also wanted to 'fill the fender flare' with the tire. He used 2cm spacers on the front and 3cm spacers on the rear.
I'm not sure if this is a the proper calculation for offsets, but I am assuming that your 70 rear offset is 15mm more dished than my 55 rear offset? As such, you might want to use a spacer a little wider than 3cm in the rear? But a 3cm will probably be good enough.
Just kind of a guess on my part, not knowing wheel offsets and that stuff too well...
Tom
