no dash lights...help!!!!
Well, finishing up putting in a new interior and when I was finnagling the little bolt on the knee pad drivers side near vent (impossible to get to!) i saw a little spark! Small wire with the rubber not fully over the connector so I pushed it all back together tight. Last night I take it out for a spin and NO DASH LIGHTS. Checked the fuses and all ok. Before I start tearing things apart anybody have any suggestions?
Thanks in advance!
Thanks in advance!
1 Post
dash lights didn't come with a fuse from the factory.. so I would check if a fuse was installed from the light switch.The dash light fuse is a good fire safe up-grade.. and you may have pulled the wire from the switch.
