Help-3.2 carrera suspension
Hi guys
Just changed my suspension to bilstein street sport, (green front, Yellow um the back...i think), and the car is higher on one side in the back...1.5cm higher...what could be the problem? Any experiences out there?
The shocks are charges and support "some" weight. The problem may have been with your old shocks, not your new ones. It may have had it's ride height set in the past with shocks that didn't hold up an equal amount of weight, one from the other. You will need to re-set your ride height with the eccentrics on your control arms.
This weekend I will be doing the same thing in putting in the bilstein street sport shocks in the rear and wonder if I will have similar issues with the front suspension..
