915 tranny help needed
Ok heres the story , car never grinded just shifted sloppy alittle hard to get into first at a red light
All the bushings were no good
The shifter bushing
The couple bushings
So like a moron i took off the coupler from the shift rod without marking it
I replaced everything all bushing put everything back
Followed the procedure to adjust the coupler to the rod several times
First time i was able to get into 1,2,3,4 with no reverse or 5th
then. Ajdusted it and able to get in 1,2 5th and reverse
Feels like no lockout for reverse
So i kept playing with it
I brought it to my friends shop who knows porsche alittle
He messed with it took the shift rod off retryed everything
It only goes smothly into 1,2 5,reverse feels like no lockout
This is with the car off
And while driving
Now when i drive it if i push hard i feel it grinding but would have to force it into 3rd which i dident do
Mechanically im somewhat inclined but i feel deep down that its simply not alighned right
I feel like im doing something wrong
Can anyone help?
The shifter bushing
The couple bushings
And while driving
Can anyone help?
My Porsche wrench said that with coupler just loose enough to adjust if you put it in third and 'shake it" you can bring it in. Never tried it myself
For some reason a clutch cable adjustment can help per my experience.
Update
Ive tried everything no luck
Still wont go into 3rd and 4th
I can engange 1,2 5th r even from the coupler
I cant engage 3rd 4th from the coupler feels stuck
Now im Thinking shift fork 3rd 4th gear ??????
What you guys think??
Can anyone recomend a shop in nyc hopefully brooklyn??
Now
Now
Linkages on these cars are very sensitive to adjustment... I had all kinds of shifting problems on my (79 SC) racer... turns out the cup on the front of the shift rod tore lose... who'd thunk it? But removing the shift rod is an enormous PIA.
Check that, and if you have a "short-shift" kit, go back to the factory...
A properly adjusted factory shifter will work perfectly every time, and it sound to me like it is a linkage problem.
Good luck.
Good luck.
