1977 not started in 10 years
Hi, I'm trying to help a person maybe sell their Porsche 911 1977. She said the husband parked it 20 years ago. Inside a covered garage, looks nice.
Can somebody give me some not started in 20 year tips.
SHould I crank it over for oil pressure but no ignition. I ask her to NOT ATTEMPT TO start it so I could ask the experts at Rennlist. She's selling it to redo the kitchen, the husband does not want to sell it. I'm trying to talk here into letting him keep it and do home equity loan. These going up in value right. It looks nice.
My first post here in the 911 group. Hello, Im' wayne. Former BMW Tech 1986-1990. Former California Smog Bar 1 and Bar 2 license. The ad. http://sfbay.craigslist.org/nby/cto/5051814496.html
Looks pretty much like all the other POS 2.7L cars that got parked about that time, as the repair costs to even keep them mechanically marginally going equated their ~$5-7K worth. Today, all bets are off, huh?
As far as what to do. Obviously, fresh oil. The pump throws enough oil around almost instantly to provide startup lubrication. If truly worried about top end lubrication, pull the upper covers and add some oil directly. Going to need a battery. And then there's the fuel/fueling situation. From the sludge left in the tank, to the fuel distributor being gummed up......one time I had a guy start up a dormant '73S, then after the old gas seized the intake guides when he ran it for awhile......he was in for a top end.
Then you're into the forensics of the brakes/axles/clutch/transaxle. And no way, no how are you not replacing the tires. But all that might be beyond just wanting to have a car with a running engine for sale.
Besides changing the oil, I bet that gas tank is nasty with the crappy gas we have these days. Have you tried sniffing the gas to see if it smells like varnish? That varnish old gas won't even fire in a lawnmower.
-Jason
-Jason
I just spoke to her, If I got it running and operational, passing smog, its probably worth 20,000 on ebay is my guess. If I put 10k of repairs and labor I would get 30K, but that's tops. My feelings. Not facts.
I'm in love with 928's. I respect the 911 as the god, yet the v8 sound does it for me. v12 does it more for me.
As for firing it up, as said, drain replace oil, pull valve covers and give a squirt. Check valve adjustment while the covers are off. Drain fuel tank, drop swirlpot screen, clean or replace. Pull fuel filter, back flush fuel lines to tank while screen is out, replace filter. Turn engine by hand for several rounds, listen for clunks, etc. Drain and re-fill transmission with Swepco. Then give it a go.
Before driving it, flush all brake fluid, replace flexible brake lines, check for sticking calipers, replace tires, do visual on rest of suspension and steering.
Before driving it hard you'll probably need calipers re-built, suspension bushings, steering rack re-build, tie rods and other assorted rubber parts such as CV boots, sway bar bushings, axle flange seals etc. Probably needs CV service or replace too.
CA smog on a 77 was not pretty. Haven't lived there is 10 years, so I'm not up on the laws anymore. Can you pull it off yet? If it's got the 5 blade fan, that's gotta go too. If head studs haven't been done (time certs) that's on the list sooner than later. AC is bad news on 2.7's as well.
To someone who knows these cars and can do most or all the work it's probably worth in the $8-12k range, depending on if the head studs are done yet. To the poseurs on Ebay, you're probably correct at 20.
The Pelican forum is a little more friendly towards the mid-years. Give a shout over there.
Cheers!
-C
If it is running you might see $20k, but to get it running it could cost you $5k++++
I dont think it would see $30k, even on a good day.
Sell it as is, barn find - $14900.
