sunroof
sunroof
I pulled my sunroof out to install a new headliner and new gaskets on my sunroof. Now the sunroof gets almost all the way to the end and stops....I need to help push it with my hand to close all the way. Any ideas on what I should adjust?
Van
Van
Generally the seal does have to break-in. be careful where the to seals overlap.Inside the seal is a white rubber like cord.If you could cut out a section about 1/2 inch long only at the overlap,the fit will be much better.Be sure and do this on both sides.
