911 wiper stop
In addition the intermitent function does not work. Any ideas where repairs need to be made?
The wiper motor has 2 power inputs, one from the switch and one unswitched. The switched power is used ONLY to move the motor off of the home/park position, the unswitched power supplies the power for ~340 degrees of positional rotation.
Turn off the switched power and the motor will continue to be powered until it reaches home/park.
I fixed this years ago on my 1979. If I remember, there are several reed switches in the wiper switch, and there is a plastic cam that closes a reed switch when the wiper lever is turned to "off". In my case, that plastic cam was worn, and was not closing the reeds. I just glued another small piece of plastic to the cam so it would completely close the reed switch.
Not only won't the wipers park with that particular reed switch open, the intermittent feature won't work either.
I was able to fix this by just taking off the plastic covers on the steering column to access the wiper switch. Can't remember if I took the wheel off too, but I don't think so. You should be able to see what is happening in the wiper switch when you move the lever, and also see exactly where the cam is not pressing on the reed switch.
Mark
