911 Forum 1964-1989
Deck Lid alignment
Old Nov 11, 2014 | 07:49 PM
racngrn's Avatar
racngrn
Default Deck Lid alignment
Gang, I put the 911 away for winter yesterday and noticed during the last walk around that my deck lid id suddenly out of alignment. I say suddenly because I know it was spot on the day before when I washed the car for storage. The right side lower edge is below the fender and the left side slightly above. The top edge of the lid appears to be fine. Both rubber snubbers are in place and the lid opens correctly from the cable pull. Any ideas as to what may have occurred and what I should look for to get it back to perfect? Hate to spend the winter worrying. Thanks!
Old Nov 11, 2014 | 08:38 PM
ron mcatee's Avatar
ron mcatee
You may have a broken rubber snubber. Check to see that it hasn't collapsed. Rubber deteriorates over time. Unscrew them and see if one is bad.
Old Nov 11, 2014 | 09:32 PM
racngrn's Avatar
racngrn
Thanks. That may be it and an easy fix. My right side bumper fell out recently and I actually found it in the engine compartment. Makes me wonder if my attempt to really screw it in well was a mistake. Thanks!
Old Nov 14, 2014 | 12:38 PM
theiceman's Avatar
theiceman
Team Owner
if i remember them correctly they are adjustable .. if you screwed it all the way in it is lower .. screw it back out a couple of turns ..
Old Nov 14, 2014 | 08:19 PM
racngrn's Avatar
racngrn
Thanks Iceman. That is correct. I have some new ones coming. I am suspicious that when mine fell out, it may have actually broken in two - hence the possibility of getting screwed back in and being way to short to align. Should be able to get to the car in the next week or two to verify. Already miss it to no end, but woke up to a few inches of snow this am. Already down to 28 and falling. Hate it....
