Replacing screen in carrera tail?
Hey Rennlist,
Does anyone know if it is possible to replace the screen that prevents debris from falling into the louvers of the carrera tail? And if do-able where can I buy the screen?
Ciao,
Alex
'87 Carrera Cabriolet
Ciao,
Alex
yes they can be replaced. If you have all factory parts there are grilles that are removed from underneath (a few set screws and 2 bolts back in the rear of the tail by where the rubber bolts onto the tail. The screens reside between those grilles and the outside body tail itself. Be prepared, the screens are expensive (approx 150 bucks) if you buy factory parts (they are a heavier screen that is molded to fit the contours of the grille and tail.
I know, i just put on new grilles and screens!
Good luck!
Good luck!
