What are these called?
Main reason I want to know is so I can find out how to reinstall them when I put the thing back together; i.e. exactly where on the tensioner plunger to they go. These appear to be right up at the end next to the idler pulley.
Also note the "black stuff" with rivulets in it below the tensioner, almost like a sludge but removes easy.
Just googled "911 tensioner locks"
http://forums.pelicanparts.com/porsc...y-collars.html
http://www.peter-iversen.com/en/webs...09690000110439
http://forums.pelicanparts.com/porsc...ensioners.html
I checked the clearance on the one pictured this morning. Almost 3mm between the stop and the tensioner body and almost flush with the end of the piston. Probably not correctly installed unless there is some leeway.
