Replating Alusil cylinders with Nikasil
5th Gear
Hello,
I am a new member of this forum and am looking for advice. I have a '87 911 and am in the preliminary stages of a 3.4 conversion that will include 964 cams, dual plug, 10.5 CR JE pistons and upgraded exhaust. I have Alusil cylinders and was looking for advice regarding the advisability of re-boring my cylinders and re-plating with Nikasil. Thanks in advance for any thoughts.
Peter
Peter
Sign up to forums.pelicanparts.com
PM me and I can help you provide more info.
RL Technical Advisor
Hello,
Peter
Peter
Thats a nice combination if everything is done right. Naturally, you will need custom software for safe operation. 10.5:1 on pump gas may be a bit ambitious unless your timing maps are conservative so I'd think that one over very carefully.
Your current 98mm cylinders can be bored & re-plated with Nikasil quite successfully and we do this all the time.
5th Gear
Hi Peter,
Such timing leaves an engine feeling a tad lethargic and not willing to rev freely.
JMHO, but I'd rather have less CR and more timing for a lively feeling motor,...
5th Gear
Only if you run with conservative timing maps, especially in hot weather. Remember, detonation thresholds are dynamic, not static and vary with outside air temp, cylinder head temp (load), throttle position, oil temp, and AFR's.
