84 Targa Clutch Noise
Good Morning:
I have an 84 Targa with about 65Kmi. Recently I have been driving the car daily and have noticed a rattle or slight grind when the car is running in nuetral. As I depress the clutch pedal the noise dissapears. When I release the pedal (still in nuetral) the noise re-appears. Any ideas/advice would be greatly appreciated.
Thank you,
Christopher
Thank you,
Christopher
[quote]Originally posted by Von Kiser:
<strong>Sounds like a possible bad throw out bearing?</strong><hr></blockquote>
What are the implecations if it is a throw out bearing? Does it require immediate attention because it will cause other damage?
Thank you,
Christopher
Thank you,
Christopher
