More barnfind fun. While (still) messing with the through-tunnel fuel lines on my SC today (still can't get the old return line out for some reason) I found a few more "interesting" things.
One of them is that the nylon bushings that the accelerator rod runs in are are all disintegrated, and all had been greased with what appears to be plain old chassis grease like was used on grease fittings in the old days. Isn't this sort of lube detrimental to nylon (or whatever these things are made of)? Seems to me I read somewhere in the past not to lubricate this type of bushing. Right or wrong? Same question about the shift rod bushing and the ball socket on the bottom of the shifter.
I also found that the P/O had installed a quick shift kit of same variety, and when I removed the steering wheel for some working room I found the upper column bearing disintegrating. The surprises just never stop.
After all these years most wear items will be worn if not previously replaced. Silicone and some synthetics can be used on nylon bushings but sometimes best to just be...any grease/lube can and will attract dirt that will increase wear...depends upon the type of bushing and its job.
The manual says lube some plastic/nylon bushings in the shift linkage arena that you mentioned.
