Clutch Pedal Stiff? May Be Your Clutch Cable! by Pelican Parts
Basic Sponsor
Prior to replacing your entire clutch mechanism, it is recommended that you replace the clutch cable, and eliminate it as a possible source of clutch problems. It is common for a failing cable to indicate the same symptoms as a bad or worn out clutch. A very stiff clutch pedal, or difficulty releasing the clutch may be caused by the cable binding or separating. Replacing the clutch cable and the helper spring on late 915 models may relieve more clutch problems that you would imagine. While you have access to the area, it may be a wise idea to rebuild your pedal cluster as well and replace the old plastic bushings with durable bronze ones.
Replacing your clutch cable is not a difficult task and can be accomplished within 2 hours.
We have the parts in stock ready to ship for that weekend project!
Take a look HERE for product details!
If this will be a DIY project, follow our step-by-step instructions HERE
Let us know what questions you have at any time!
Mark/Pelican Parts
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
![](https://rennlist.com/forums/signaturepics/sigpic303_8.gif)
Team Owner
i did this exact project when i first got my car. the cable and the bronze bushings. a very rewarding diy project. this and the door stay reenforcements i consider the two best projects i did
(Replaced countless clutches back when I had my shops due to improper clutch adjustment that ended up killing the pressure plate.)
Team Owner
Team Owner
Then for Step 2, make sure you've got the thing adjusted correctly. Especially important on the '77-'86 transmissions that do have the helper spring.
Team Owner
too true .. i wonder if im the only one **** enough to climb under and check theat 1mm time to time ..
Team Owner
not that there is anything wrong with that ..
okay back to your regularly scheduled program.
I haddah Google dat
I haddah Google dat
No, no...of course not on the TO bearing.
I mean on the cable. Make the cable just slack-free, then adjust the gap to 1.2 mm, then tighten cable to the famous 1.0 mm gap. Now the cable has .2 mm pre-load or whateveh. Gap is still 1.0 mm to the TO arm.
BTW..2 hrs to replace the cable is slackin' !!
