Over lowered Targa?
On Ebay. Otherwise a seemingly decent ride but way too low in the back correct? Is this easily adjustable or something that would likely require hardware changes? Been looking for an affordable targa, thanks!
http://cgi.ebay.com/ebaymotors/1980-...#ht_593wt_1080
Front looks alright rear is too low. Otherwise looks very clean... And sport seats!!!
You can adjust the rear height (or a shop can) without too much trouble or $$$.
EDIT: not sport seats...
Something's up with the ignition switch. Visible in the photo that shows the closeup of the steering wheel through the driver's door. It looks like it's been drilled, there is no slot for the key.
Re-index to set the rear torsion bars to correct ride height, alignment and corner balance. Maybe $500 if there are no surprises with the spring plates?
Mark
Mark
If somebody is seriously interested in the car and wants to speak with the mechanic who performed all work mentioned in the advert, then please PM me.
This mechanic is a true enthusiast.
What a moron to slam the rear like that! Does it also have hydraulics setup for East LA??
Other than that, nice car
I haddah Google dat
The front looks ok, especially if the spindles were raised, but the rear is definitely too low. I would probably raise both the front and rear if the suspension is stock. Probably a couple hours of work, then a few more to align the wheels.
That SC is really clean. It still has the stock York compressor and R12 fittings.
