Lowering the front
Lowering the front
Hi guys, tried to lower the front this evening but did not make it. From an older post I know that a good approximation of the Euro ride height is 25.5" at the front and 25" at the rear (measured from the floor to the fender lip). I have 26.5" at the front, 25" left rear and 25 1/4" right rear. I've read that adjusting the front is a snap, adjusting the rear is a bit more complicated. I tried to lower the front. I have the Bently (front torsion bar adjusting is at 440-9) and also read the article at Pelican Parts. Found the adjusting screw. if you unscrew it any more than it is now it will no longer press against the edge of the torsion bar end. if you turn it in the opposite direction, where it is plenty of room, basically all the screw threaded portion, the front will raise instead of going lower. Am I doing something wrong or is there something else? the article at Pelican says that if you can’t get the correct adjustment you may have to remove and adjust the location of the torsion bar adjustment lever that fits on the end of the bar. Anybody had this issue? thank you
George
'79 911 SC
George
'79 911 SC
