911 Forum 1964-1989
Clutch Shaft Stiffness
Old May 12, 2013 | 07:25 PM
Steam Driver's Avatar
Steam Driver
Default Clutch Shaft Stiffness
How difficult/easy should it be to move the clutch T/O fork shaft on the G15? It seems to me the one in my transmission moves pretty stiffly, enough to "ride" the clutch. Is that what the assist spring is for, to negate that, or should I take it apart and lubricate it?
It just seems too tight and sticky to me. More than I would have expected.
Old May 13, 2013 | 04:25 PM
ron mcatee's Avatar
ron mcatee
Steam Driver, what's a G15? Is it a 915 or a G50? If it's a G50, you probably haven't had the shaft modification done to the fork.
Old May 13, 2013 | 06:43 PM
Peter Zimmermann's Avatar
Peter Zimmermann
For the 915, the TO fork shaft should turn smoothly with light pressure.
Actually, if you let go of the shaft, while installing the fork retaining pin, the shaft will fall out by its own weight if it's pointed down. Take it apart, clean & lube it!
