retrofit AC into a non AC car?
Rennlist Lifetime Member
I'm looking to buy a 3.2 Carrera and have found a car that's almost perfect except for one thing - there's no air conditioning. AC was an unusual option in the late 80s in the UK. Is retrofitting an option? I would find an AC equipped car at a breaker's yard and get all of the items (lines, compressor, condensers, evaporator, wiring, etc) but are there body or chassis mods required? I would probably upgrade some of the components to ensure it was as effective as reasonably possible. Any advice as to what might be involved would be appreciated. I know that "anything's possible" but is it realistic?
I would check into aftermarket AC. Probably cheaper and more effective than the stock stuff and if you do some more research, you will find that you have to replace about 1/2 the stock stuff to have a really good system.
I appreciate that the need for AC is a personal preference - let's just say my strong preference is to have it.
I would use some of the aftermarket components from Griffiths, retroaire or the like but I figure some of the basics will need to come from Porsche and some mods might be required. So my original question remains - is my aspiration realistic?
Based on the few times I have been in the UK over the years I would guess that your summertime climate is much like ours around here. In that case I suspect you would get more than sufficient A/C with just a factory system but with one or 2 updates..
Binary pressure switch to control and protect the compressor.
In my opinion you can add 2 extra cooling fans to the rear lid condensor and forget the front condensor/fan.
Use a trinary pressure switch instead and run the fans based on the 3rd switch function.
In the UK you can get away with basic setup:
Compressor; compressor mount;engine mounted condensor;receiver dryer;barrier hoses;smugglers box evaporator unit; temp and fan control switches. I don't think you need the complication of the front condenser.
Rennaire is a little less expensive than Griffiths and should be sufficient for UK.
Factory evaporator unit, rear condensor and switches could be sourced from dismantler.
You don't need any rear condensor fans, I ran the setup above for years in Mexico where the temps are about what you get in the UK summer, high 80's, to very low 90's.
But our resident expert, Kuehl, is on record (***1) as saying that the addition of the binary pressure switch is a highly desireable add-on feature, virtually a requirement if converting a factory system from R12 to R134a.
***1
a.) Prevents damage to the compressor should refrigerant level get too low.
b.) Prevents the compressor from driving the system pressure beyond system design pressures, 350-450PSI, should the thermostatic switch control system fail "on"/closed.
c.) Based on Kuehl's recommendation (ref. "b"), and the EPA's test results, it may be entirely possible to use the factory "non-barrier" hose provided the binary pressure switch is used to prevent system overpressures.
***2
Another recommendation of the EPA is that should the conversion to r-134a result in to much loss of A/C cooling capacity an extra fan might be added to move more air over the existing condensors. Increasing their efficiency thereby overcoming the loss due to R-134a.
My suggestion, supported by the factory reaction to the initial system design (add more refrigerant condensing capability) and by the EPA, is to use a TRINARY pressure switch. Use the extra switch element, just as do the majority of modern day 24/7 automotive A/C systems (Porsche included), to "power" additional condensor cooling fans.
In this case 2 radiator cooling fans "sucking" airflow downward through the rear lid condensor.
Skippy
Douglas aka Amber Lamps has directed me to this thread as I am putting the a/c system from my 1986 Carrera on the market. Let me know if you are interested in one way or the other. The a/c was in working order but I cannot ensure that it still is at this time.
