911sc 1980 brake upgrade
Bill if I get the rotors from the boxster and fit them to the car will that work and then use the boxster calipers so I would have a full set of boxster brakes on my car
It should give better braking as I currently have the stock setup and the rotors are quite small
I would also end up with better looking brakes
If I get the adapter kits would this work
thanks
thanks
I have seen 996 rotors used but beyond that I don't know details except that the hubs are modified, I personally don't see how
from left 996 rear, 996 front, 911 rear rotors
uninformed gas bag
(contemplating on whether gas bag is one or two words)
Standard Boxster and just the front. One of the front calipers was bad so we replaced them both with these.
I sold it before I went all the way.
Parts Specialist
Bill V and Steve W are your wallets best friend and it's worst enemy
they will save you from spending money on things that dont work
but convince you that the right "upgrade" isnt cheap
I agree 100% with Bill's comment to do a little more research - having dont some upgrades myself - Bill V was 100% spot on as to the info I needed,...and then I was able to make th choice that fit me best - and my wallet
I'd start by ditching the 18" wheels, those just don't look right on these cars.
I ran 993 calipers all around with 309mm Wilwood rotors up front and stock rotors at rear. Stopped and looked good in 17" wheels. Also fit inside my old BBS 16's.
I ended up buying this kit
https://www.porscheshop.co.uk/porsch...rsche-911.html
I had guys from auto haus do the work +353 87 988 3633
Over all it was expensive but I ended up with much better breaking and they look much better then the stock
Addicted Specialist
Edward
it's called BLING!!
Two real reasons to alter the brakes:
1. you lack brake torque
2. you lack cooling
#1 is rarely (never?) an issue
#2 is best addressed by technique or ducting in some air tho you can add thermal mass by putting big rotors on your car (which will also increase wt. on the wheel, harming handling)
what we really need is reliable & cheap PCCBs for old cars
(I hear Tesla is working on a kit for us...)
2. you lack cooling
Rotors
Chris
