911 Forum 1964-1989
dipstick size?
Old 02-28-2013, 11:00 AM
mextremem
mextremem's Avatar
Default dipstick size?
DOes anyone know the length of a 1977 930 dipstick. Seems to be taking more oil than the required amount to hit the dipstick full level.
Old 02-28-2013, 12:23 PM
Peter Zimmermann
Peter Zimmermann's Avatar
What do you consider the required amount?
First, there's no need to fill the reservoir all the way to "max" on the dipstick. Halfway between "min" and "max" is perfect.
Second, make sure, when you check oil level, that the front oil cooler is hot to the touch, the engine is idling, and the car is parked on level ground.
Third, if you removed the old oil while the car was still warm, it might take as much as 11.5 quarts to reach half-way on the dipstick. The recommended process is, after the changing oil & filter, to add 10 quarts and drive the car until it's up to full temp. Then follow #2 above.
Old 02-28-2013, 02:20 PM
mextremem
mextremem's Avatar
yes 12 quarts when I do oil change. Gettiing alot of oil in oil filter and not sure where its coming from. Thanks Marc
Old 02-28-2013, 07:01 PM
SARGEPUG
SARGEPUG's Avatar
My '77 dipstick wasn't very long, I was only 7rs old! Sorry, couldn't resist!
Old 02-28-2013, 09:18 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,118 Likes on 800 Posts
well i would say if you are getting lots of oil in your oil filter and you,re not sure where its coming from ... then auto mechanics is not ur calling
Old 03-01-2013, 01:55 PM
porsche0nut
porsche0nut's Avatar
I was expecting that to come from Ice!
Old 03-01-2013, 05:31 PM
rusnak
I haddah Google dat
rusnak's Avatar
Seriously! I wast sure it was going to be something along the lines of "not all dipsticks are created equal" or some such
Old 03-01-2013, 06:01 PM
theiceman
Team Owner
theiceman's Avatar
i couldnt make the statement it wasnt very long
Old 03-06-2013, 06:35 PM
AL_93
7th Gear
AL_93's Avatar
I just bought an '84 3.2 Euro and when I check the oil (at operating temperature, idiling) the car will stall when the filler cap is removed--unless I pinch the oil vent hose with vice grips. Its like the thing is drawing too much air when the oil tank cap is removed. What do you guys think is the cause?
Old 03-06-2013, 06:53 PM
rusnak
I haddah Google dat
rusnak's Avatar
You either have a missing oil line restrictor (looks like a brass cone) in the crankcase breather hose, or a massive vacuum leak.
Old 03-06-2013, 07:15 PM
AL_93
7th Gear
AL_93's Avatar
I was thinking that there must have been some restriction valve/device in the hose somewhere that the previous owner removed (now I wonder why they would). I looked at a diagram and think that I see the restrictor that you reference. Is it hard to get to ?
Old 03-06-2013, 07:53 PM
SARGEPUG
SARGEPUG's Avatar
Something wrong there Al, all that should happen is a slight adjustment to the rpms when you take off the cap.
Old 03-06-2013, 08:15 PM
rusnak
I haddah Google dat
rusnak's Avatar
No, just feel for the restrictor by squeezing the hose. If it's new, then most likely the hose was replaced and the PO forgot to transfer the restrictor over to the new hose. Not hard to replace.
Old 03-07-2013, 11:04 AM
AL_93
7th Gear
AL_93's Avatar
Thanks! I think that its at the end of the hose at the oil tank--right ?
Old 03-07-2013, 08:50 PM
Peter Zimmermann
This might help...the restrictor slides into the end of the hose.
Quick Reply: dipstick size?
