87 911 G-50 Short shift kit
No doubt that the G50 short shift kit WAS a FACTORY option on my '89. As someone else demonstrated, it's an option code and is noted on the original window sticker. No aftermarket stuff needed in that case,..it is truly PORSCHE!
BEST!
Doyle
BEST!
Doyle
On my '89, I have the option of M243 ---- Shorter gear shift lever
According to Kindel's site, M341 is central locking system
http://www.kindel.com/porsche/options/options.asp
IIRC the 89 25th anniversary model was also delivered with short shift & LSD as standard so porsche definitely had them back then.
Does the Wevo & porsche kits differ in anyway in terms of result or operation?
On my '89, I have the option of M243 ---- Shorter gear shift lever According to Kindel's site, M341 is central locking system http://www.kindel.com/porsche/options/options.asp
https://www.stuttcars.com/technical/...des/911-84-89/
and in fact I have a small pilot to open/close the car
cheeRS
Darek
