oil for breaking your nuts!
Machinest Mag published this note on what works best....since we are some serious nut busters thought you might like to see it.
Machinist's Workshop Mag recently published some information on various penetrating oils that I found very interesting. The magazine reports they tested penetrates for break out torque on rusted nuts. They are below, as forwarded by an ex-student and professional machinist. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
Penetrating oils Average torque to loosen
No Oil used ................... 516 pounds
WD-40 ...................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF.................................53 pounds
Power Steering Fluid.........51 pounds
I used it on all the exhaust nuts on the 911 without breakage. If something is really stuck, I apply the 50/50 mix, let it set overnight, then apply some heat via MAPP gas. Works like a charm.
The Acetone is very light and acts as a carrier by pulling the ATF down the threads. I've looked at some of the nuts/bolts I've pulled apart and it appears that the mixture will penetrate down about 5+ threads.
It is cheap and effective. I don't waste money on PB Blaster any more.
I keep the bottle swirled/mixed when using it and it appears to work OK
Oh yeah, where the hell have you been?
I haddah Google dat
Haha!!
I've been busy setting up, running, then tearing down our annual Pumpkin Patch and Christmas tree lot.
We had fair rides, food, cotton candy, a stage with karaoke 3 nights a week, live bands, etc. It was a freakin blast. I should post pics for my Rennlist brothers!
RL Technical Advisor
Interesting subject!
PB Blaster is more placebo than useful and I don't know any shop that uses that stuff.
There are a few professional-grade penetrants that are useful, one of which is Kroil. I use a Zep product (its on my website) with excellent results since a bottled liquid is difficult to apply in many situations, especially upside down.
Acetone is a toxic substance and not something I'd use around here as we go to a lot of effort to maintain a healthy working environment, given what we do. Caveat Emptor to those that do.
