911 Forum 1964-1989
Need replacement door pockets
Old Sep 18, 2012 | 04:57 PM
wolds's Avatar
wolds
Default Need replacement door pockets
Hello all. I need to replace the driver and passenger door pockets on my 83 SC. Looks like I have a few options so I'm looking for your advise. Pelican has fiberglass replacements that I could have covered by Classic 9 in carpet ( looks like $949 + shipping). Sierra Madre has fiberglass pockets with domestic carpet already installed ( $748.84 shipping included). With over $200 spread between the two I'm thinking of going with Sierra. Has anyone gone with either of these options or taken a different approach? Thanks, Warren
Old Sep 18, 2012 | 05:33 PM
theiceman's Avatar
theiceman
Team Owner
id be looking on ebay and going to swap meets
Old Sep 18, 2012 | 06:10 PM
ron mcatee's Avatar
ron mcatee
Why are you having to replace them? Are they broken? If not, can buy carpeting for them and recover them. Just need some upholstery glue and an air stapler.
Old Sep 18, 2012 | 07:33 PM
Amber Gramps's Avatar
Amber Gramps
What is wrong with the ones you've got?
What color are you looking for?
I ask, because I just deleted a perfect set of blue ones from my car. I got RS/RSR cards from Bob at www.appbiz.com and covered them in suede. The kit came with black Perlon for the door pockets that I did not use. Bob goes full retard when it comes to making the perfect carpet kit. Not only did I get what I asked for, RS carpet for a Cabriolet, but I got all the parts that normally come in the kit made for a coupe.
So basically some of what you need may be sitting in my shed as we speak. Let's make a deal.
....or just ask Bob to produce the parts that you need. If all you need is the carpets for the door pockets that's a no brainer at Appbiz.
(PS: The kit's sold at SM and PP are made by Bob anyway. )
Old Sep 18, 2012 | 11:14 PM
wolds's Avatar
wolds
That price I quoted was for the pockets along with the covers just to be clear. The reason I want to replace the pockets is that the mounts are cracked and I don't think I'll be able to make a satisfactory repair although I won't know for sure till I get them off the door panels. The covers are warped and are in bad shape. I am looking for black pockets and covers. Warren
Old Sep 19, 2012 | 02:40 AM
salukijac's Avatar
salukijac
I bought a repair kit from this site for $65. It worked really well. I ended up recovering my pockets because my carpet was not in optimal shape.
The guy also carries the ABS pockets for $300/pair.
https://sites.google.com/site/911por...orpockets/home
Old Sep 20, 2012 | 10:53 PM
Carrera3.2LG50's Avatar
Carrera3.2LG50
Take a look at dC Automotive.
Looks like they might have some used black door pockets. http://dcauto.gotdns.com/illustration/index/475791753
Old Sep 21, 2012 | 12:02 PM
wolds's Avatar
wolds
Well, I looked through the pile of carpeting that the previous owner gave me when I bought the car and discovered that I have replacement carpeting for the door pockets already. I will need to pull my old pockets and see if I can repair them. If not, I can buy the replacement fibreglass ones from Pelican. I think that the carpet has to go around a compound curve on the bottom corners which means that I would cut and fit as required. Is this fairly easy to do? Thanks, Warren
Old Sep 21, 2012 | 12:05 PM
theiceman's Avatar
theiceman
Team Owner
i would say it may be worth spending a couple of bucks and just giving to a profesional upholsterer to do if you are unsure. cant be that expensive to do 2 door pockets.
Old Sep 21, 2012 | 12:15 PM
wolds's Avatar
wolds
I might do that. I need to take the car over to the local upholstery shop anyhow to see if they can repair the zipper for the top. Warren
Old Sep 21, 2012 | 08:36 PM
salukijac's Avatar
salukijac
I took mine to an upholsterer after I repaired them with the kit above. I think it was about $150-200 with the replacement carpet from GAHH. My pockets must have teflon on the inside because the carpet came off already on the top part. This was also a problem I had with the previous one as well so make sure you take steps to prep that area.
Old Sep 22, 2012 | 08:10 AM
wolds's Avatar
wolds
Thanks for the info, I'll keep that in mind.
Old Sep 30, 2012 | 06:50 PM
rstarga's Avatar
rstarga
I bought some ABS ones from the site above about years ago and he recovered them for me. Very good quality.He even trimmed them with leather edging The fibreglass ones I bought from appbiz are crap.
Old Oct 1, 2012 | 12:22 PM
Ghosteh's Avatar
Ghosteh
What about the mousehair insides? Mine are faded and look a little ragged. Is there any way to re-dye or recover them without getting complete new pockets?
Also, what are the originals? ABS? Is there a noticeable difference when you replace them with fiberglass? My original ones are very slightly warped... just enough for someone with OCD (like me) to notice, but not bad enough to warrant $800 replacement. Oh, the irony!
Old Oct 1, 2012 | 03:28 PM
wolds's Avatar
wolds
I talked with Bob at Appbiz earlier today and apparently he doesn't sell replacement pockets. He did give me some advise on how to straighten out my warped ones using a piece of aluminum riveted along the top edge of the pocket. The other issue I have with the old pockets is that the screw hole closest to the door handle is cracked. I think this can be fixed fairly easy though.
