A/C Blower Fan Nut Tool
Ok, guys I did a search, but couldn't find anything. Does anyone know where I can find the special socket or if one even exists to remove the A/C fan nut that holds the A/C fan switch in place. This is the one in the console. I have a short in the switch and I am hoping that if I can loosen the nut a little it might solve the problem. Otherwise, I may just replace the switch. Either way, I have to get that nut loosened.
Thanks in advance.
Thanks in advance.
If you are referring to the the flat 'washer' like nut with the slot in the face (aka 'rosette') behind the a/c thermostat and fan speed switches in the center console ....
pull off the switch ****, you can use a flat bladed screw driver and carefully give it nudge. If you scratch of the black coloring simply use a black felt time marker for touch up.
