Bill, thanks again. Is it common in the Porsche community to run that large of a spacer (60mm)? I've never used anything larger than 25.4 on other vehicles.
The only Porsche that I know of that ran large spacers was 930 rear, early 930s also ran a fair sized one though 1/2 the size of the rear until they redesigned the front spindles in '80.
21mm front spacer 930.341.611.00
54mm rear spacer 930.331.911.04
Porsche needed a special dispensation from Tüv to run the large rear spacers.
In general I try to avoid any spacers, they add weight, reduce rigidity and can introduce rotational issues.
