911 Forum 1964-1989
Comments/Advice
Old Jun 22, 2001 | 09:15 PM
roger911s's Avatar
roger911s
2nd Gear
Post Comments/Advice
Just walked away from a 911S in NYC-area when the seller got squirrely on me for wanting to get a PPI from a "guru" other than his (who I can't find any independent comments about). He's got a highly modified 67S engine (10.5:1, Webers, MSD ingition, etc.) in a rough but mostly rust-free 77S Coupe shell. (Don't ask why, I never got a straight story about the transplant.) The car seems 'okay' but has oil weep seller says is from a "leaking oil return tube or loose nut on cover" and is not firing on #1. Now I learn it had a tensioner failure that was just fixed (non-carerra tensioners used) and all rocker arms sheared off but there was no damage to valves. I suppose it's possible, though I'm not sure how likely. No leakdown/compression was performed after tensioner/ramp installation. The shared experience and wisdom of this board will be appreciated, as I have no experience with these early (sand cast aluminum case) engines.
Old Jun 22, 2001 | 09:44 PM
Dial 911's Avatar
Dial 911
Post
You say you "walked away"...I would have ran away!
Old Jun 22, 2001 | 10:31 PM
john walkers workshop's Avatar
Post
keep walking.
Old Jun 22, 2001 | 10:39 PM
horst's Avatar
horst
Specialist
Post
ANYONE WHO WILL NOT ALLOW A INDEPENDENT PPI IS SUSPICIOUS. DON'T LOOK BACK. THERE ARE TOO MANY REALLY GOOD 911s out there.
