A what does this wire go to thread
That's a very good point Doyle I shouldn't go jumping the gun thinking I'm ok. Trying not to sound to much like a novice (but I am) what is a VR? Voltage Regulator? And where would be the best place to check the voltages of the system? What voltage is acceptable?
And also to Pete I would like to thank you for your book it was a trusty guide while going through the purchase process.
Point of measurement would be the battery. I see around 13.7 VDC when running,..a steady read,..(yes: some days it can be up a bit,..others, lower.)......doesn't really vary much with RPMs,..varies only with electrical loads that would be applied (lights, AC, etc.)... Just wanted to ensure that your charging system is good-2-go.
Other measurements would be what the battery shows when it's time to crank it....I usually see ~12.6 VDC (I do believe this to reflect a fully charged battery (i.e., not 70%,..nor 80%).
Aside from that,..with this extraneous current draw,...it would be prudent to check your fuse box connections (clean/burnished) and to have a close look at all fuses (healthy?)..
I'm sorry: was there an answer as to these (additional???) wires and the issue they provided you?
Best!
Doyle
Best!
Doyle
