Premature Valve Guide Sucks (re-post)
All is good, but the state of the engine was surprising. Chris, while testing the engine on the emissions tester (the CO2 needed to be adjusted a tad) stated "100 cars will come through here before you'll see another with an engine that tight". It was spewing less than 50PPM of hydrocarbons; Chris says anything below 100 is really good. Note I have a cat-bypass too.
http://www.flickr.com/photos/ckindel/2447515900/
Yes, the car only has 35K on it, and yes, I baby it, but you also have to recognize that this engine had a top-end job done when the car had only 6800 miles on it!
Thinking about this, this week, made me realize that many of you on this forum might enjoy reading that story. I originally wrote this an put on my "Porsche Pages" (www.kindel.com/porsche) in 1997.
Enjoy...
Charlie Kindel's Sad Saga of Premature Valve Guide Wear
I posted the story of how I came to own a 1988 911 with only 6800 miles on it in the spring of 1997. Since buying the car I have had tons of fun and, for the most part, my experience owning a Porsche has been nothing but pure joy. However, there have been problems. The largest of which is disclosed here in the sad saga of premature valve guide wear...
Here's the story so far.
On Thursday, June 19, 1997 I sent the following message to the Porschefans Mailing List:
They did the work today, and claim that the valves are adjusted as they should be. They claim that my valve guides look worn. This car now has only 8400 miles on it!!! How could this be?!?!?
The service manager's suggestion is that I just drive it like this for a while and eventually get a top-end job done (~$2000!!! Eeeeek! My wife's gonna kill me!).
Questions I asked, and answers I received:
Q: Will they get worse (I think the noise *has* gotten worse since I've owned the car)?
A: Probably.
Q: When do I know I really need the top end job done?
When the valves get REALLY noisy?
A: I don't have a good answer for you. Sorry.
Q: If they get worse, will they cause more damage (making a top-end job even more expensive or even ruining the engine)?
A: Possibly.
Q: What should I do?
A: I really don't know. You need a top-end job.
Q: But the car only has 8400 miles on it!?!?
A: I know, I've never seen anything like this.
This bites. Does anyone have any opinions (stupid question for this list ) on what I should do? I don't remember reading anything in the 1000s of pages I've read about 911s where this era of car had any sort of chronic valve guide problem.
What could have caused the guides to wear like this?
The oil consumption specified by Porsche for the Carrera 3.2 engines is 1.5 liters per 1000 Km (or approximately 1.6 quarts per 620 miles). I consider this to be excessive, so your 3 quarts per 1,000 miles is completely out of hand.
Over the past decade there have been a number of different theories on why the intake valve guides and/or valve stems are wearing out on the Carrera 3.2 engines, we never saw the earlier 911 engines with intake valve or valve guide problems. The latest theory, offered by a couple of my friends; Ted Robinson of German Precision and Dwight Mitchell of Autosport Technology is that the wear is caused by the Viton valve stem seals used on these engines. The theory is that they work too well and prevent the guides from getting adequate lubrication causing the intake valves and guides to prematurely wear out. Usually sometime between 40,000 miles and 60,000 miles this wear shows up and by then the valve stems seals themselves have also worn out and the engines will have excessive oil consumption, plug fouling and all the rest.
Usually a good indication of worn valve guides is noisy valves, the valves should be quiet on a 911 after they have been adjusted. If the valves are noisy you should have your mechanic check the valves for valve guide wear. You can check the valve guide wear by pushing the valves from side to side with a screw driver with the valve just lifted off of the seat a few millimeters (about 10 mm). You can actually judge how worn the guides are with this method.
Bruce Anderson
I went to the dealer and asked them what they could do to help me. I told them that I felt that Porsche and/or the dealer should pay for at least part of the repair cost (which was now estimated to be around $3500!). The dealer said they would cover 30%. To me this meant that they would simply not make a profit. So I wrote a nice letter to Porsche Cars of North America. I explained my situation, including an exerpt from Bruce Anderson's email.
Soon I received a reply telling me that they valued me as a Porsche customer and the dealer had their full authority to "take care of me". With this letter in hand I returned to my dealer and was told that together Porsche and the dealer would cover 60% of the cost. This, I could live with.
I mean, it's not like the car is still under warrantee. It is 10 years old and Porsche certainly had no technical obligation to pay for the repair. But there is clearly a problem that could be only caused by a defect in workmanship or materials. So I took them up on their offer.
I dropped the car off on November 12 (I waited until the weather around Seattle was supposed to turn bad...as it turns out we had a beautiful stretch. Sigh.) The service manager said it would take about 10 days. I asked the service manager to call me when they had the car disassembled so I could come in and check it out. When they called and I went in I took a bunch of pictures with my digital camera. The heads had already been sent off for work so I couldn't see them (or the valve guides) but I was able to see the rest of the engine and transmission in it's disassembled state. Cool.
As I expected the mechanic found a few other things that "needed work". For example, he felt that it would be a good idea to replace an oil return hose. He also noted that there was a service bulletin on the G50 transmission. Apparently the shaft for the "throwout fork" (see image 14) had a poor bearing design. The service bulletin calls for machining in a new bearing race in the lateral shaft, and this can greatly improve the life of the clutch. Since my clutch only has about 11k miles on it now, I figure the cost of the parts (he's not charging me labor) is worth it. Another item that he fixed was the cylinder head temperature sensor; it was upgraded to the two wire design (the original was a single wire unit that got ground from the cylinder head and was known to be unreliable).
I got the car back on Saturday, December 6, 1997. I had to pay about $1700. This included 4 intake valves, all 12 valve guides, the clutch update, etc... This was 40% of the total cost. Porsche and the dealer paid the other 60%.
The ticking is gone and the motor feels like new. The clutch feels smoother. I'm completely satisfied and excited to have my car back.
FWIW, here are some pictures I took while the engine was apart in 1997:
The 3.2 Carerras did seem to have more valve guide issues than the SCs. This was largely due to the too-soft valve guide material from the factory from what I have seen. How the car is driven plays a major role as well. The fact that your car had this issue with only 6800 miles in 10 years speaks volumes. When these engines experience a lot of cold starts and short trips, the top end of the engine does not receive adequate lubrication, being the furthest part of the oil circuit from the oil pump. The 911 oil system holds a lot of oil and it takes a while for it all to warm up and thin out enough to lubricate the valve guides.
I have a number of customers with 3.2 Carreras with over 200K miles, and a couple over 300K without the engines ever being apart. These cars are driven and fully warmed up regularly. I constantly stress this to my customers with garage queens. If the car sits a lot, at least be sure that the engine is fully warmed up and driven properly every time it is started. Not only do you have more fun driving it, but it will pay off in the long run.
Now go out and take your beautiful car for a nice long drive!
