Emissions Failure
My 88 Targa failed CT emissions. The results were:
HC (Limit) 156 - Car scored 39 Pass
CO (Limit) .50 - Car scored .61 FAIL
NOx (Limit) 1094 - Car scored 1083 Pass
Any ideas on what I can do to get the car to pass?
One more year and its over 25 years old and no emmisions! But this year is a different story.
Thanks, Mike
Thanks, Mike
I haddah Google dat
How old is the O2 sensor? Last time the engine had a complete tune up? Fresh gas? Should be easy if you start with a good running motor, and check the air/ fuel ratio.
can the '88 motor be detuned for emissions like the 911sc motor by turning the CIS CO adustment down on the sensor plate?? then retuned(dialed back up) after test??
I haddah Google dat
Not really. The O2 sensor will take over, and the DME will follow it's program. Changing the parameters (chip, AFM clock spring) are semi permanent, and best left to pros.
Team Owner
the nox is right on the limit too. that cat is working overtime
did you put the corre t grade fuel in ? if you put high test in and your car is incapable of burning it tbis will result in higher emmisions also if hour oil is old it will show higher emisions when bur ing.
if you havnt i would do a tune up change the oil and go back for retest
i remember my father in law(a retired boeing engineer)telling me you can get a car to pass by pouring a certain amount of rubbing alchohol into the fuel tank prior to the emissions test - anyone up on this technique? - would it work?
http://www.911chips.com/fuelsys.html
Note, re the fqs, you might try position 3, or make sure someone didn't move it from position 0 previously. Again, testing w gas meter is crucial. Good luck!
I would def suggest an oil change as well if the oil is getting close to it anyways, and it def appears your cat is showing its age
whatever you do please fight the urge to use seafoam or its relatives, unless you really feel like paying for a new cat....
hell dude your so close you should prop just wait for a warm enough day and try again haha
its really ashame some states like california still require emissions on cars older than 25 years - state of washington only requires cars later than 25 years old to pass. and this is a tree hugging, EPA'd to death state.
i can understand these states wanting to cut back on emissions but you have to laugh about it regarding california when you see the tens of thousands of boats/jetskis/lawn mowers and weedwackers w/50:1 mix buzzing away all day. with the bagillion lawyers in calif., some must be frustrated enough that their collector cars won't pass - i'm surprised none put up a good enough challenge to get some sort of exemption.
this year anything older than 1988 is exempt in the state of washington.
i can understand these states wanting to cut back on emissions but you have to laugh about it regarding california when you see the thousands of boats/jetskis/lawn mowers and weedwackers w/50:1 mix buzzing away all day.
"can the '88 motor be detuned for emissions like the 911sc motor by turning the CIS CO adustment down on the sensor plate??"
Actually you can. The 911 3.2 has still basically the same overall system functionally
as the 911SC, i.e. a fuel delivery system with an O2 sensor. In either case the
O2 sensor has a limitation on how much it can correct the mixture. If the AFR
is adjusted beyond the O2 range, the AFR can be changed.
Obviously, the O2 sensor could be left to look like it was still connected and then
the mixture leaned (by adjusting the internals of the AFM - for a 3.2). If the
O2 were left connected then a greater AFR (mixture) change would be required
to force the desired emission level.
