Fault Codes
Plugged in a durametric to check my fans were kicking in properly after I found a stone jammed.
It's identified a fault code on my car (C2S) which I need to understand.
P1682 - Secondary air valve final stage
Any idea where I can look this up or what might be the trouble if any - No problem with the car that I am aware of.
