What am I missing here?
Have an approximately 5" round hole in the rear engine bay just to the left of center ( as you face the engine bay ). Found this pic ( see arrow pointing to something - this is my hole ) which seems to have something there - can someone tell me what I'm missing? Thanks
its where the smog ump used to be that is now removed . it used to run off the fan pulley and ran the pump which would force air down into the ehaust injector tubes for pollution control . I may have a pic to help clarify
yeah mine is gone too .. someone fabed a nice piece of sheet meatl on mine , tacked it it and spray painted it ..
BTW you should check to see if you still have your spider underneath ( the tubes ) and injectors. I cut up and removed all mine to clean up underneath. I think i did some kind of write up a few years ago if you do a search
