Noise: Right front shock
If you can get the bumper shock out, then you could run a dye and cut new threads into the bolt. You'd probably convert the threads to SAE with the same thread pitch. If you get that far, a good hardware store can set you up with the tools and parts.
While I once felt like a blind man, my vision is becoming better with regards to this stuff.....just need a shove in the right direction.
The die worked perfectly.......10 minute job and then got the bumper snugged up. 5 minutes was used putting the darn rubber back on the front bumper....sheesh, that was a challenge.
I had a slight wheel pull on the drivers side and decided I would attempt to FIX it. I adjusted the driver side caster a bit forward and the passenger side a bit back w/o moving the camber and BINGO, she drives straight. Now I will double check the camber and toe and hopefully they did not move much during the caster adjust.
The byproduct of the caster adjust is that the passenger side noise calmed a bit which gives me a bit of confidence that the buldged sway bar bushing on passenger side will be the final piece to the 'noise' resolution.
Thanks again for the ideas.
I will try that out this weekend....nonetheless, correcting the drivers side steering pull (caster adjust) has quieted the noise significantly which in my non-mechanical, but common-sensical brain was a result of taking some tension off the right sway bar. One thing I did notice when correcting the caster angle is that both sides are NOT in the same position.....I suspect this can be attributed to partially failed sway bar bushing (3/8 inch play) as well as aging suspension parts. I'm hopeful that the new bushings will straighen things out a bit as well as correct my noise.
